Home > Maintenance & Mods (L405) > How long do your pads and discs last ? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I normally get 25/30k to a set of discs - and I am quite heavy on the brakes / don’t hang around.
20th Mar 2022 8:23pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1381 |
I'd expect way more than 11k miles out of a set of pads, let alone discs which should last at least 20-30k miles.
20th Mar 2022 8:27pm |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 89 |
Thank you for confirming that they should last longer than they have, I will be phoning the dealer in the morning to discuss the mater... Roger Young in Saltash if anyone knows them 2016 AB SDV8 Barolo black |
20th Mar 2022 8:36pm |
20th Mar 2022 9:09pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
If the pins for the front pads tap out easily, then they have been out. recently, but if they are seized, then they haven’t been out for at least 2 years roughly.
20th Mar 2022 9:10pm |
recordman Member Since: 08 May 2013 Location: Kent Posts: 114 |
Mine's on 39,000 and it went into a MD for a service last week. On the video that they sent me the guy said that there was 8mm of material left on the front pads and very little disc wear. The rears had 5mm left and the discs are showing signs of wear, but 'nothing to worry about at the moment'.
20th Mar 2022 9:23pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
They have simply not been changed for what ever reason... Heavy usage would be 25k gentle use can see 50k between brake changes... |
20th Mar 2022 10:39pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
I fully agree with CTC's above comment, in well over thirty tears of maintaining my cars, I have only had to change the brake discs on three or four cars, one being my current FF. the discs I removed were very, very old and had been on the car for many years. The 'new' discs ( Pagid ) now have about 10.000 miles on them with no discernible wear at all. |
21st Mar 2022 1:42am |
This morning the low pads warning was no longer showing on the dash. I had a look at the pads as best I could and the ones I could see still have meat on them.
21st Mar 2022 4:51pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
If it has been used a lot for towing that could be reflected in heavier rear brake wear. John
21st Mar 2022 6:27pm |
