Home > Technical (L322) > Jacking and supporting the rear end |
This help?
20th Mar 2022 11:26am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3191 |
That’s the problem with the workshop advice - the A arm attachment point is not usable as a support point when the suspension is fully extended 2012 TDV8 Vogue (L322) |
20th Mar 2022 11:47am |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
As I do have a ramp I do not use a jack that often, but car can sure be lifted under the airspring under the A-arm. I do this all the time when car is in the ramp when I lower it down on the axle stand, and when in need I support it onder the jacking point. Although I don't know if you can jack up that high with just a jack (surely you won't get the Sprinter bottle jack under it), so you'll need a (low) hydraulic floor jack with appropiate lift capacity (>1500 kg) and lifting height.
20th Mar 2022 1:39pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
I always jack the rear under the air spring albeit with a trolley jack. Never had a problem. I also place an axle stand under the rearmost jacking point with a lump of timber between the jacking point and the head of the axle stand. |
20th Mar 2022 3:56pm |
Made up a couple of spigots for the top of my axle stands to match those on the sprinter jack so I can transfer the jacking point adapters I made to the axle stands to support the rear on the jacking points when I lift via the A arms under the air spring.
21st Mar 2022 5:01pm |
