Home > Technical (L322) > "special programs off message" help please
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Robert are they the only codes? have you scanned each module for codes?
i would scan each of those modules looking for a hard code that begins with somethin other than a U.
the other point is if you can scan each module then they are communicating on the BUS. If you find a module you cannot read then this is the likely culprit.
I have had issues recently got a bunch of U codes HSC, ABS, Special Programs and a couple of others. After changing the battery they kept coming back. scanned each module and the ABS module reported speed sensor rear left. i have a separate post as to what i found but changed the sensor and all codes went to history as soon as i started the car and moved it. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #623247 11th Feb 2022 9:35am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
That’s very useful, thanks going to do that this weekend!!!
Thanks for the tip
Best regards
Robert
Post #623248 11th Feb 2022 9:37am
Sandyt
Hi Robert I too had similar messages and mine was nearside rear ABS sensor which was playing up it would throw the fault first thing as I reversed out the drive replaced all the sensors in my case and never looked back.
Post #623310 11th Feb 2022 6:07pm
Robert
Thanks for all your help, finally found out what was wrong.
The French "specialist" told me to replace the ABS module (I did n't)
Had to go to Holland en made an appointment with a specialist overthere, according to them
it was my steering angle sensor. That part was not on stock (thank god, 7 hours work...)) So I drove back to France.
After two and a half hour in my car with the GAP tool found out that in the carconfig, the Hitachi pump software and the AMK pump software were active....(Don't ask me how that's possible)
Looked in the rear and I have a Hitachi pump, reflashed the software...and magical...all the faults cleared, the system works and once again the GAP tool proofed it's value. Thumbs Up Thumbs Up
Post #626323 16th Mar 2022 6:23pm
Jayk69
good to hear you got it sorted. Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #626363 17th Mar 2022 9:09am
Robert
Thanks Jay.
These cars are just to complicated.
After de tips on here I had a new battery put in (mine was not even a year old) to no effect. OK 300 euro gone with the wind.
I was at 3 so called "specialists", the stealer found the same messages as I had and only talked about replacing height sensor, ABS sensor, HDC module etc...all in all more money as the car is worth.
The specialists "found" a lot of replacement work.
Nobody has obviously taken the time to look into the car configuration.
It took a non tech like myself and a GAP tool and patience to solve it (without any costs)
Isn't it sad. Hope in the UK these specialists are better. Here in France they are complete id....
As I often say: great and beautiful country but the French are like their matches, it takes 3 to lighten a candle.
Thanks to you all!
Regards from a cold and wett South West of France
Robert
Post #626378 17th Mar 2022 12:48pm
Hvaca
United States
How did you end solving the “Special programs off” issue
Hello, I am having the same issue. I have a OBD tool, not the GAP, but I’m hoping I can solve the problem.
Do you happen to remember how did you solve the “Special programs off” issue?
Thank you!
Post #695952 11th Jul 2024 1:51am
