Home > Maintenance & Mods (L322) > Rear wheel bearing 2011 tdv8
DrRob
New tyres have not solved it.
Getting annoyed now! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625429 5th Mar 2022 3:58pm
DrRob
tb10 wrote:
Dr Rob, are you sure it’s not one of the bushes? I had a similar issue on the SC and I replaced the bearing but it didn’t get rid of the drone but then I replaced the top rose and bottom bush and it’s been fine since.
Regards
John
John
Can you try and describe the noise for me? Difficult I know Whistle
ta
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625934 11th Mar 2022 9:45am
dhallworth
If it's definitely coming from the rear then the only other things are the other bearing, the diff or the driveshafts.
If you can hear it from 10mph though that is odd as unless they were *really* bad I'd not expect to be able to hear them at that speed.
Have you tried draining the rear diff oil to make sure it's not sparkly? Has it got any worse since you posted originally? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #625946 11th Mar 2022 1:37pm
DrRob
Diff drain is next and prop inspection.
What "other" bearing are you referring to?
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625948 11th Mar 2022 2:14pm
dhallworth
I read your post and thought you'd only replaced one wheel bearing so wondered if it could be the bearing on the other side.
Post #625951 11th Mar 2022 3:52pm
DrRob
Gotcha Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625985 12th Mar 2022 9:26am
DrRob
Looks like one or both rear driveshafts....will confirm soonest Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #627577 2nd Apr 2022 8:13am
DrRob
Nope. Not that.
Run out on hub was checked and out of range..
Back to the drawing board Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #628012 7th Apr 2022 9:38am
DrRob
Regards
John
John
Was your noise like a wind drone type noise or metallic noise?
Ta
Post #628014 7th Apr 2022 9:40am
