![]() | Home > My Range Rover > My Favourite L322 Mods! |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Just thought i'd share a summary of all the mods i've done on my 2011 4.4 TDV8 Vogue SE, and hopefully gives others some ideas:
If you don't have a keyless car, check out the Bentley key upgrade available on ebay. They cut the blade to your photo then all you have to do is drop the transponder in and follow the programme procedure: https://www.ebay.co.uk/itm/125077836566?ha...SwQ51hztiG LED Comfort Lighting (like the L494 and L405) Ok so not strictly necessary but after having an L494 for 6 weeks, i really appreciated having a faint hue of light glowing from the footwells. This was a really straightforward install - set the lights to white and minimum brightness and leave be! ![]() Aluminium Pedals A touch of retrained class for £12 and a 5 minute fit.
Hardwired Dash Camera Don't look like a Poogeot driver with a suction cup and cabling dangling everywhere, serving no more than to demonstrate your ineptness. Hardwire it properly. 2006-> Bluetooth Audio (Non Bovee/Invery) If you have a 2010-> car and can't afford the Bovee/Invery ipod adapter or have a 2006-2010 and want bluetooth audio without cables on show, then here's your answer! 3D Numberplates (and 4D) No photo for you on this one because i want to keep my privacy. Check out Utopia Plates I got great service from them and super quick delivery. They do a Range Rover plate option. 2x 3D plates cost me £40 delivered - absolute bargain. If i were to reflect, i think the FFRR can get away with 4D plates without looking chavvy.
Custom Fit Boot Mat I had a lovely quilted vinyl wipe-clean boot mat made for my L322. Ordered it on Aliexpress (just search L322 boot mat and loads of options come up). Keeps the dirt off the carpet and i just remove it and wash down with the hose. It cost me £24 delivered. ![]() Heavy Duty Vehicle Ramps I do not trust plastic or cheap Chinese welding on vehicles this heavy and a sloped surface. If you're like me and want absolute certainty your vehicle ramps won't fail, this is a really easy job!
redsportt Member Since: 31 Dec 2015 Location: n ireland Posts: 14 ![]() ![]() ![]() |
Would you have a link to the site you bought the boot floor mat from please? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Nice. I did exactly the same with the puddle lamps and LEDs on my L322. Also, as yours is dark too, smoked side repeaters could be a plan ... What do I put here then? |
Link not available anymore. Just search "L322 boot mat" on Aliexpress and loads come up. 2015 Range Rover Autobiography 4.4 SDV8 |
I want any mod to be true to the restrained elegance of a Range Rover so, any change has to be subtle. A smoked light definitely wouldn't do it for me - clear, yes. But also no animations. 2015 Range Rover Autobiography 4.4 SDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I put LED bulbs in the side indicators to match the rest of them.
Exactly this kind of thing although, have to be careful as new MOT guidance basically says all driving lights must be incandescent or specifically designed LED units, not fittings designed for incandescent with an LED bulb.
Yeah. Appreciate that… old bulbs in the boot.
