Home > Maintenance & Mods (L322) > Brake Caliper Banjos & Washers
dhallworth
Evening Gents,
Does anyone know what size or even have a part number for the washers that go on the banjos on the brake flexi pipes?
I’m rebuilding my calipers at the moment and wanted to replace the washers but it from what I can see the banjos aren’t available separately from the flexi hoses and the washers don’t seem to be listed either.
Primarily need the front ones that go into the Brembo calipers but the rears wouldn’t go a miss either.
Thanks for any help Smile
Post #625857 9th Mar 2022 9:40pm
Merchy
Don't know which sizes you need,could well be different from my Td6....But... the easy answer, is to buy one of the copper washer kits as in the example..... (link below) kits are cheap and then you always have plenty of spares on hand. Use these kits at work for numerous systems and high pressures.
https://www.ebay.co.uk/itm/353372907461?ha...SwIftgF5vX
Only tip to add is that if the copper washers seem to be hard / inflexible, then anneal them before fitting, then they are effectively self sealing.
Alternatively.............If you have the 'Dowty seal' type washers (hydraulic seals) then the below kit should see you right
https://www.ebay.co.uk/itm/384453100276?ha...SwVHBgwghZ
Both types obviously available in Imperial and Metric, hope this helps, apologies if I am preaching to an engineer Whistle Thumbs Up
Post #625864 9th Mar 2022 10:44pm
dhallworth
Thanks Merchy
I’ve just ordered one of these from Amazon in the hope that one of the sizes will fit.
https://www.amazon.co.uk/dp/B08PJW1R11/ref...81_TE_item
Post #625865 9th Mar 2022 10:52pm
