Home > Technical (L322) > Adaptive dynamic suspension top pins
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
I'm getting the dreaded adaptive dynamics fault. A mechanic looked inside the top bit where the solenoid is, and he said it looks like there's a pin missing. There's usually 2.it's there a fix for this? I don't mean the me hardness /plug. It's what the plug goes into.
tia
Post #624734 25th Feb 2022 3:48pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
First thing to check is its not the harness /wire having broken. This the usual cause of the adaptive damping fault. Was the error open circuit or similar?
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #624749 25th Feb 2022 6:53pm
stuartj9
I can see there's only one pin there abd 2 in the other side. Says front right damper solenoid. Using icarsoft
Post #624756 25th Feb 2022 7:57pm
stuartj9
Any ideas?
Post #625039 28th Feb 2022 7:54pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Can you see if a pin has broken off as I suspect there should be two pins per side. Check in the plug on the cable and see if the other half of the pin is in there 2011 TDV8 Vogue SE
Post #625052 1st Mar 2022 7:42am
stuartj9
There's one pin when I look into the top of the damper. On the other side there are 2. It's the one pin side that's giving me the adaptive dynamics fault. Everything else is OK.
Post #625053 1st Mar 2022 7:48am
dennij
Can you look at the plug end and see if there are two small holes where the pins would connect to 2011 TDV8 Vogue SE
Post #625054 1st Mar 2022 8:46am
stuartj9
Yes, there are two female connectors
Post #625055 1st Mar 2022 8:50am
dennij
If you have two holes in the plug end but only one pin on the shock I would say that one pin has broken off, perhaps someone might be able to confirm by taking a picture of theirs to confirm 2011 TDV8 Vogue SE
Post #625057 1st Mar 2022 9:29am
GraemeS
2 pins are required to complete the circuit. If the missing one is totally missing, not bent out of the way, then a new shock is required.
Post #625058 1st Mar 2022 9:32am
stuartj9
Oh no! Crazy how the top bit can't be replaced. Guessing it's 600 ish because a pin is broken. I was hoping there mightve been a repair kit for it or I could fix it as the shock is fine.
Post #625060 1st Mar 2022 9:37am
