![]() | Home > Technical (L322) > 4.4 TDV8 Vibration/Rumble - RPM related |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
have you checked the UJ's you seem reluctant too but if the center bearing went this could have prematurely warn them and these will also give you the symptoms advised.
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
Hi, not reluctant at all - there were no obvious signs of the centre prop UJ having any play when I removed it to change the centre bearing.
apologies i just looked at the set up of the 2012 prop and see there is only 1 UJ on the rear the other articulating joints seem to have a different set up. 2012 Vogue 4.4 TDV8 - Current
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1304 ![]() ![]() ![]() |
I have a noise that is slowly getting louder as time progresses. It is like a gentle whining which occurs in each gear at about 2000rpm.
@Jayk69 - no worries, you reminded me to do another graph I forgot about |
I'm slowly getting all the pulleys to do the whole lot. I've got a genuine water pump and tensioner.
Admittedly I was going to get them from Advanced Factors:
Update.
As you can see the turbo shut off valve itself doesn't appear to be the issue, as it opens almost immediately after is is commanded to. So the issue seems to be whatever (sensor(s)?) tell the ECM to open the turbo shut off valve @ ~2400rpm. FYI, I also cleaned the following sensors yesterday; MAPT sensor (caked in black soot/oil), 2 x MAFT sensors and the air charge temp sensor which hasn't resolved the issue. Today I added jubilee clamps to all the small vacuum hoses as they could literally slip off with the touch of a finger. They don't appear to be collapsing when the engine is running and are in otherwise good condition (holding their shape). I've been underneath and I can't see any obvious issues with the vacuum hoses around the secondary turbo or the wires. Any input appreciated! |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 821 ![]() ![]() |
Hi
You're right about the revs dropping back into the rumble zone...I've got too many graphs now to sift through but If I can find the one Ill post it up - showing the valves staying open as long as you don't let it drop below 2400rpm (and it doesn't make a noise unless you do and start the cycle again).
Graph showing the CSOV & turbine valve remaining open so long as you don't let the revs drop below 2.4k - and no vibration experienced unless you do.
Graph making me think there is a boost leak as manifold pressure drops as revs rise beyond ~1838 (note, I have no error codes logged which relate). This happens at random rpms as they rise over multiple tests. So my theory is either boost leak or MAPT sensor is dodgy - I might try to test it with compressed air and a gauge. |
Small update
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2653 ![]() ![]() |
If not already done, you might want to remove the throttle body intake hose to see if the butterfly has been closing. Normally there would be an indication of where it was closing to as carbon builds-up on the manifold side.
Hi Graeme thanks for the reply (I've been looking at some of your past posts recently - see below)
