Home > In Car Electronics (L322) > Battery drain |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
You can start here:
26th Feb 2022 7:52pm |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 |
well i did all measurements again ...
26th Feb 2022 10:19pm |
Yakk1564 Member Since: 29 Mar 2022 Location: Neath Posts: 2 |
Probably not relevant to all range rovers on here but upto 4a chassis there was a problem with the hevac unit causing the vehicle to keep waking up, I've read your posts very interesting, the bonnet switch you can pull it upwards goes into vallet mode so don't need to disconnect, fold a small piece of paper and stick it over the small fan on the hevac unit then just lock car and wait 20 mins the park light should go off on the gear selection and the piece of paper will fall off the fan, if the park light comes back on it means the hevac unit has woken up again and the whole system carrys on trying to shut down for another 20 mins constantly draining the battery, also leave the rear parcel shelf up and side door removed inside as the satnav is 1 of the last units to shut down when red light flashes and then goes off, hope this helps anyone.. |
25th Apr 2022 6:30pm |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
Further to the last post I understand from Land Rover that a "kit" was available - masically it was an ignition fed relay that disconnected the main feed to the HVAC unit. |
3rd May 2022 6:24pm |
