![]() | Home > Technical (L322) > Rear light replacement |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2589 ![]() ![]() ![]() |
Very easy to replace, if you upgrade you may need a resistor, ebay is your friend for replacement, not sure if LR are still doing them but if so they will be expensive relatively |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
Yes, as above, dead easy… 2 bolts you can see on the side with the lower tailgate open, and then you have to ease it straight backwards off some rubber sockets.
I think you may be able to get an aftermarket lens and swap your cracked one, but never done it and it might involve glueing…..
If you try to remove the rear lights after removing each of the two screws they should pull to the rear of the car but probably won’t, they are likely to be stuck. I had this issue first time and resolved it by cutting a piece of softwood to a shallow taper and inserting the tapered end into the gap between the front end of the light fittings and the bodywork and gently tapping the piece of wood into the gap. This had the effect of driving the light fittings rearwards unsticking them.
