Home > Maintenance & Mods (L405) > Engine Oil Level - Not Available [4.4 SDV8]
Page 2 of 3 <123>
Chris thegasman
United Kingdom 2014 Range Rover Autobiography SDV8 Barolo Black
What engine are you asking about
Post #624675 24th Feb 2022 11:20pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
2011 RR Vogue L322 4.4 72,000 miles, recently purchased, all good apart from no reverse lights ( fuse check tomorrow ) RR owner
Post #624676 24th Feb 2022 11:25pm
mpirie
There is an oil extraction tube on the 4.4''s fitted to the 322.
It's on the offside front, between the airbox and cylinder head. It's plugged by a small black plastic bayonet at the top of the tube which was presumably where the dipstick would have gone.
Mike
Post #624694 25th Feb 2022 10:11am
Baltic Blue
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #624708 25th Feb 2022 11:24am
Old-un
Thank you, I will experiment. RR owner
Post #624710 25th Feb 2022 11:40am
Baltic Blue
If you have no reversing lights, don’t rule out both bulbs blown.
The elements are very fragile when hot, and slamming the lid breaks them.
Post #624714 25th Feb 2022 12:20pm
Old-un
Fuse number 12 changed, bingo we have 2 reverse lights ( for the time being )
Don't know what caused the fuse to blow though. RR owner
Post #624740 25th Feb 2022 5:18pm
Podge_healy
Ireland 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi Everyone... Hope ye might know anything about this..
Is is possible the digital oil gauge can give a false reading?
I had a cracked inlet manifold and was leaking oil.. I've since replaced the 4 of them and I topped up the oil as it was showing low..
Drove it around 250 miles and now its showing min again (I put in 1 litre and it makes 0 difference..
Now I'm afraid to drive it.. Gonna get mechanic to take all oil out and measure it.
(white grey smoke when starting engine that covers the yard 😬... Goes away after 10 seconds... Guessing this was oil in the intake from the leak.
Post #641385 29th Aug 2022 9:54pm
Old-un
Have you sorted this and if so what was the diagnosis ? RR owner
Post #649221 26th Nov 2022 5:13pm
HYUN
Hello Zebedee
Hello Zebedee
I live in South Korea and have L405 TDV8 4.4 Y2014.
The engine oil level checked by the instrument panel is not intermittently displayed in my car.
So I searched to purchase a dipstick that can be done manually, and I saw Zebedee's writing here.
Could you please upload the dipstick on eBay?
I'd like to check the engine oil level
I can't speak English, so I used a translator.
Please understand.
I'll be waiting for the reply.
hyunracing@hanmail.net
Post #698035 14th Aug 2024 1:42am
HYUN
Zebedee wrote:
Update:
I believe I'm closing in on a solution for this:
- The small diameter bass guitar string seems to work just right and better than strimmer wire.
- 0.6mm heat-shrink cut into rings then heated to fix onto the guitar string are just right and don't move.
- High level seems to be 73cm from the end of the oil extraction tube and low level is 78cm (I'm going to continue to test levels when I find different 4.4s).
- It's important to warm the car, then let the oil settle for a couple of hours before taking a measurement. Only the first reading is accurate.
- Let me know if you need a dipstick made - I might put a couple on eBay.
- I'll continue to work on the canister concept to house the sensor in a separate unit outside the engine.
Hello Zebedee
Hello Zebedee
Please understand.
Post #698036 14th Aug 2024 5:56am
Zebedee wrote:
Craig - that would be brilliant. Thanks.
I’ll make one up and post it to you.
Did you ever make one Zeb?
Post #702692 20th Oct 2024 2:40pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Sorry Craig, no I never did. Too many other things going on.
I'm sending the one I made with the car when it sells. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #703648 3rd Nov 2024 11:26am
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
I have tried this but cannot get the wire to go all the way down, is there some trick? (L405 4.4 2018) 2010 3.6 TDV8
Post #706408 8th Dec 2024 6:23pm
Zebedee
No, no trick.
The thinest bass guitar string is definately best, but the next size up also worked when I tried it. There are some quite tight right hand angles so I suspect yours is getting caught up on one of those. Did you file down the end so there is no sharp bit at the bottom? Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #706416 8th Dec 2024 7:49pm
Page 2 of 3 <123>
