Home > Technical (L322) > Deployable side step |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
On mine, I have them greased every service. Apparently they can get clogged and jammed with dirt.
23rd Feb 2022 5:02pm |
Whussain5 Member Since: 18 Feb 2022 Location: Wakefield Posts: 15 |
Brilliant thanks Ivan I'll take it off tomorrow and grease it up to see if that helps
23rd Feb 2022 5:05pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1190 |
It will work for longer if it`s clean, putting a lot of grease can hold more dirt? using a good CRC silicone spray and not WD40 will help? |
23rd Feb 2022 10:04pm |
I shall do that. Thanks for the advice |
23rd Feb 2022 10:07pm |
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 |
I had the same issue a few days ago, I gave the hinges a good flush with WD40 and they work again and I intend give them a good grease up or maybe looking at fitting a grease nipple. Range Rover Vogue SE 4.4 TDV8 |
24th Feb 2022 8:34am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
I think fitting grease nipples would be a great way of sorting the lubrication issues with these. Filling them with grease would help keep the dirt and corrosion out.
25th Feb 2022 12:55pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 742 |
my experience of the brackets on these suggests that they're not particularly strong and the design doesn't look as if its nipple friendly.
25th Feb 2022 2:27pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1226 |
Try this
25th Feb 2022 3:39pm |
When I get a chance I will have a look about the possibility of grease nipples, if brackets are really unfriendly you could tig a nut or something similar to mount a nipple or even drilling a hole half way through the pin and then drilling again at right angles.
27th Feb 2022 10:54am |
