![]() | Home > Technical (L322) > Engine Warning Light |
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 ![]() ![]() |
Noticed after starting this morning that engine warning light has stayed on. Car runs well and no warning messages displayed.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
could be an air leak from the engine breather hoses
Could easily be a Lambda sensor on the CATs.... |
If you don't want to pull your trousers down for the BlackBox Solution then you can just buy an OBDB reader off of eBay. I use a USB one that plugs into the laptop, it cost me £25 and has been used countless times and must have saved me a small fortune in trips to the stealer to get the light reset and to read the code to enable me to diagnose at home. This will only read engine trouble codes though, nothing relating to the rest of the car.
Thanks for the replies.
Damn, didn't find the RSW when I started looking for a diagnostic tool. It sounds lot cheaper than the BBS with similar functionality. Am pretty happy with the Faultmate though, especially once I got it to program the new (expensive) key fob !! MY 2010 5.0 SC Galway green and sand interior!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
it'll be no good for you as you have a 2006 full fat...the RAC only goes up to vins 5A999999.. ... - .- -.
