Home > Technical (L405) > Restricted performance at 60mph (fault codes below) thoughts
Pez02
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Restricted performance at around 65mph, notable louder whistling than normal. Re-setts after turn off for around 5 mins.
The AA turned up and kindly told me I needed to take to a garage report below. Thumbs Up
Engine control - 7BA / Diesel EDC 17CP11P006A - Intake manifold pressure/ air mass meter. Error Message : Malfunction.P169F - This fault code can be ignored.. Error Message : Too many signal changes.P040D - Exhaust gas recirculation temperature sensor A. Error Message : Malfunction.Fault codes as stored, suspected air leak, member to take to local garage.
Any thoughts before it goes in tomorrow? Thanks in advance
Post #624283 20th Feb 2022 9:25pm
GraemeS
Are the 4 short hoses that connect the air intake to the manifolds still the bellows type? If so then 1 or more may have developed a split.
Post #624295 21st Feb 2022 2:14am
Have you removed the engine cover for a gander yet?
Post #624297 21st Feb 2022 4:01am
Pez02
Removed engine cover cannot see anything unfortunately, goin gin today will report back
Post #624299 21st Feb 2022 7:58am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Quote:
goin gin today
Is that before or after you get the repair quote Rolling with laughter 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #624302 21st Feb 2022 8:19am
Pez02
Been diagnosed as a split manifold
Post #624347 21st Feb 2022 5:58pm
Pez02
For info m, replacement of the split manifold I’ve been quoted £396 + vat for original part and 8 hours labour at £45 a hour. I have warrenty wise 06/60 cover and I will email over the garages quote and report back. Thanks
Post #624409 22nd Feb 2022 12:32pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
£45 per hour is cheap!!!
Post #624418 22nd Feb 2022 2:59pm
Pez02
Warrenty wise suggest it should take 1.5hrs and have covered the parts cost.
Post #624421 22nd Feb 2022 3:54pm
Dolphinboy
Total bill for my 2011 L322 (inc VAT) at MJ Fews (Ex MD) was £1660. This was the Pax side inlet manifold. It is tricky because all the injector leads need to come out. Mine is now working perfectly again for over a year. Not a bong or a ping!
Just seen your 1.5 hrs Shocked and raise you 6!!
Post #624422 22nd Feb 2022 3:54pm
Pez02
They have covered 70% of the cost but I am going to challenge it.
Post #624423 22nd Feb 2022 3:59pm
