![]() | Home > Technical (L405) > Restricted performance at 60mph (fault codes below) thoughts |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2565 ![]() ![]() ![]() |
Are the 4 short hoses that connect the air intake to the manifolds still the bellows type? If so then 1 or more may have developed a split. |
Have you removed the engine cover for a gander yet? |
Pez02 Member Since: 24 Nov 2019 Location: South Yorkshire Posts: 21 ![]() ![]() ![]() |
Removed engine cover cannot see anything unfortunately, goin gin today will report back |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
Is that before or after you get the repair quote ![]() 2013 Freelander 2 SD4 HSE Luxury |
Been diagnosed as a split manifold |
For info m, replacement of the split manifold I’ve been quoted £396 + vat for original part and 8 hours labour at £45 a hour. I have warrenty wise 06/60 cover and I will email over the garages quote and report back. Thanks |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
£45 per hour is cheap!!! |
Warrenty wise suggest it should take 1.5hrs and have covered the parts cost. |
Total bill for my 2011 L322 (inc VAT) at MJ Fews (Ex MD) was £1660. This was the Pax side inlet manifold. It is tricky because all the injector leads need to come out. Mine is now working perfectly again for over a year. Not a bong or a ping!
They have covered 70% of the cost but I am going to challenge it. |
