Home > Technical (L405) > Heated/Cooled seats
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Heated/Cooled seats
The heated seats in my 2013 SDV8 VSE do not get very warm in the seat area. The back rest warms up very quickly but, the seat portion does get warm, but not much more than lukewarm. Also when choosing the heat zone, you can only have the backrest or the entire seat i.e. no seat base. Does this point to a failed duct/Peltier in the seat base?
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #624215 20th Feb 2022 9:53am
i believe the heated / cooled seats are supplied by cold or hot air whereas the range rover heated seat only options have a heated element ..
does the cool work ok cos i suspect the air ducts or filters might be clogged up.. ... - .- -.
Post #624221 20th Feb 2022 11:49am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have a similar issue with both fronts on my 2017 supercharged so interested in any replies. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #624239 20th Feb 2022 1:50pm
IGP
Hi Stan
Yes, the cooled setting works fine. In which case, if the seat heating is supplied by hot air, it may suggest that the car needs to be warm enough to heat the seats up. I'm not too bothered but the wife does complain they are not as good as the ones in her Freelander Shocked .
Thanks
Post #624301 21st Feb 2022 9:15am
Merchy
Found this on the site, it may help you Question Thumbs Up
https://www.fullfatrr.com/forum/topic51084...seats+work
Post #624305 21st Feb 2022 10:21am
IGP
Thanks for that. I will buy a new filter and see if that makes any difference. As I said before, the seats do get warm but not that warm. I don't really want to start taking them apart as I have not had heated seats in any car so what you have never had you never miss Smile
Post #624317 21st Feb 2022 11:22am
