Home > Technical (L405) > TPMS programing
jackcramerr
TPMS programing
Does anyone know how TPMS can be programmed ?
I have 4 wheels (LR OE) and they don't have TPMS in them. So thinking of getting TPMS from ebay (new OE LR part), installing them on the wheels and then program them.
But what tool would I need to program them?
Thanks
Post #624084 18th Feb 2022 2:29pm
knwatkins
I appreciate your wheels don't have the sensors, but is your vehicle fitted with TPMS? Does it have the antennae in each wheel arch, behind the liner? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #624086 18th Feb 2022 3:27pm
...also it would help if your car profile was filled in... ... - .- -.
Post #624089 18th Feb 2022 3:38pm
jackcramerr
Thanks guys.
Story is, it had 20 inch wheels with sensors.
I changed the wheels to 21 inch. They are LR ones as well but didn't came with sensors. I drove car for a month with no issues and now tpms warning came up. I hadn't thought of tpms and assumed it all worked meant the 21inch wheels have them.
So I got OE sensors, 4 of them. But not sure what next will need done aside form the obvious that I need to get them installed in the 21 inch wheels.
I don't want to remove the sensors from the 20 inch wheels unless I have no choice.
It's a P400e btw.
Post #624092 18th Feb 2022 4:02pm
knwatkins
You just need to install the sensors into the wheels. No need to reprogram anything as far as I know. Kev
Post #624093 18th Feb 2022 4:05pm
AnotherMutley
From my foggy memory of doing this, there's 2 different frequencies and I learned the hard way and bought 4 of the wrong ones and seem to remember using my friends Autel to turn them on.
Post #624095 18th Feb 2022 4:11pm
jackcramerr
The ones this P400e takes is LR070840. It's 433Mhz after a Google search.
I will be surprised if just driving them will program them as I think every sensor has a unique ID so it does not start to read from another nearby car.
I looked into Autel over YouTube. And seems Autel can only program its own brand of TPMS.
Post #624129 18th Feb 2022 8:14pm
CS
When I bought a set of wheels with TPMS from Duckworths I wondered about this. It turned out that they automatically set themselves when put on the car. I change wheels summer and winter and no problems. So assuming you get the right TPMS sensors it may well just work. My fallback was to ask the dealers to do it, but not needed. Only Range Rovers since 1988
Post #624130 18th Feb 2022 8:48pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
I have a MY2015 with TPMS 433Mhz I put a set of winter wheels from a 2018 with TPMS and the car automatically picked up the new wheels and started monitoring as normal 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #624430 22nd Feb 2022 5:20pm
Kot
When I had a flat the TPMS found the spare immediately and while I drove the car without a spare,
the system on start up would send an amber lite on the dash telling me there was no spare in the boot!! Very clever
it really is that simple 2018 SE SDV8 4.4 Byron Blue
Post #624481 23rd Feb 2022 10:34am
jackcramerr
Took old wheels with sensors and new sensors along with the new wheels to a garage. They said the sensors will need programmed and requires specialist Range Rover tool. They said the specific tool has some ethernet cable connection.
Post #625069 1st Mar 2022 10:57am
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
Not sure about programming but the sensors are often shipped in a "sleep mode" and need to be activated by someone. See here https://www.fullfatrr.com/forum/topic58856.html?highlight=tpms for further details. In my case I went to Landrover who activated them for me.
Post #625071 1st Mar 2022 11:21am
a quick research shows that an activation tool is required if you fit new sensors...what i can make out is that its a handheld device that you point at each sensor [in wheel] and wake up the sensor..
there are various makes on ebay etc but theres not much info to whether these units work on a landrover.
i'm sure a dealer will do this job for you. ... - .- -.
Post #625073 1st Mar 2022 11:38am
mlambton
I have just had some new OE sensors fitted by a local garage that refurbs wheels (apparently the originals broke apart when he tried to remove them). However having fitted the wheels back onto the car it appears that there is no recognition of the actual tyre pressures. I guess I will also have to get the Dealer to reset the monitoring too. I will report back when they have had a look. 2015 Range Rover L405 SDV8 AB Corris grey
Post #625919 10th Mar 2022 5:16pm
