![]() | Home > Maintenance & Mods (L322) > Bleeding the ABS........ |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Any ABS system I have ever worked on has required a diagnostic tool to open the valve block and allow air through it.
Grizzly Member Since: 01 Oct 2021 Location: Cheshire Posts: 5 ![]() ![]() ![]() |
Thanks for the reply.
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
Before you go any further, clamp off all the four flexi pipes and then see if the pedal is still soft, if it is you may have a problem with the ABS. If the pedal is hard, check the pistons in the callipers are tight against the pads, I had this problem after overhauling the callipers (I notice you fitted new) and the pistons were pulling back ever so slightly thereby giving a soft pedal as you were pushing the pistons out before they moved the pads 2010 3.6 TDV8 |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
you can try to bleed abs unit by few hard stops on grass surface, this will activate abs but you won't put too much stress on the components, I saw that in the youtube video: LR time - discovery 3 - how we replace brake lines.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
Or you could try operating the HDC |
