Home > Technical (L322) > Steering angle sensor replacement |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 98 |
Hi!
14th Feb 2022 10:58am |
You were corrrect! Got the old one out and a new one in.
15th Feb 2022 10:25pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
And just to add, you will need to recalibrate it or it will throw up abs and suspension faults. |
15th Feb 2022 11:20pm |
Yeah I know. But now I can at least connect diagnosis again. The faulty SAS was blocking me from reading codes. Now I can again, but icarpro is useless, so it wont calibrate my SAS even though it says it can. So will try lynx |
16th Feb 2022 6:54am |
The codes will never go away until this is calibrated, right? Tried wheel to wheel turning to see if it would reset (not forever, just until car was moved) but yellow lights were there non stop. But icarpro says it must be calibrated so reckon its whats needed |
16th Feb 2022 6:56am |
Correct, lock to lock only re sets it, it needs calibration first. |
16th Feb 2022 11:48am |
This has been a strange one.
19th Feb 2022 9:29pm |
Only thing I can suggest is check for faults in all other modules, did have sas fault pop up in lcm on the 53 plate. |
20th Feb 2022 7:51pm |
Read out speeds on the sensors while driving slowly, and the replaced sensor show 8 km/h while the three others show 4 km/h, so I think the ABS module believes the front right wheel is spinning and therefor runs the dsc. |
20th Feb 2022 7:58pm |
Duff new sensor then, do remember reading about somebody having same thing with a replacment sensor. |
20th Feb 2022 8:18pm |
Will cough up for an original one this time. |
20th Feb 2022 8:21pm |
