Home > Technical (L322) > Budgie in my engine |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
If chirping not affected by rpm, are you sure it is accessory belt / pulleys ?
15th Feb 2022 4:15pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3262 |
It's coming from the front of the engine low down on the left and if I spray WD40 down there it stops. 2012 TDV8 Vogue (L322) |
15th Feb 2022 4:20pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Did you change the one top left as you look at the engine?
15th Feb 2022 5:22pm |
Mine was and was the main culprit for budgie noises...or more like a budgie being killed Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Feb 2022 5:23pm |
No idea as the garage did it and assumed they changed the lot. 2012 TDV8 Vogue (L322) |
15th Feb 2022 5:54pm |
15th Feb 2022 6:00pm |
Should be on your invoice to cross check part number Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Feb 2022 7:12pm |
13deg this morning and no noise on startup. 2012 TDV8 Vogue (L322) |
16th Feb 2022 5:07pm |
Think it's oil on the belt dripped down from spilling it while topping up without a funnel. Not easy to clean as it's so inaccessible. I can see a possible method with a stick and a pad soaked in brake cleaner to hold under the ribbed part as it's moving but it's not ideal and there's a ( big) risk it would slip and.... 2012 TDV8 Vogue (L322) |
3rd Mar 2022 10:39am |
Gave it a good squirt in detergent from a hand sprayer while it was running just now. Definitely a belt contamination issue as the chirp is exactly in time with a white marking on the belt and it goes quiet when the detergent was first squirted on ribbed side. May need a few applications to cure it. 2012 TDV8 Vogue (L322) |
3rd Mar 2022 11:47am |
