Home > Maintenance & Mods (L405) > Minimum Disc Thickness? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1391 |
My wear indicator light has come on for my front brakes and I wanted to check the disc thickness to see if I needed new discs at the same time as the pads.
12th Feb 2022 12:28pm |
Thanks
12th Feb 2022 3:09pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1199 |
I dont know, they will test the brakes if they pass, they pass but if your pad thickness alarm is on thats another matter 2018 SE SDV8 4.4 Byron Blue |
12th Feb 2022 3:13pm |
But the dealers are keen to check it for you for obvious reasons 2018 SE SDV8 4.4 Byron Blue |
12th Feb 2022 3:14pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Minimum disc thickness for the front is 31mm
13th Feb 2022 8:37pm |
For MY18 JLR spec
13th Feb 2022 9:38pm |
Yes, it's marked on the outside edge Kev
13th Feb 2022 10:07pm |
Thanks all.
14th Feb 2022 2:13pm |
