![]() | Home > Maintenance & Mods (L405) > Minimum Disc Thickness? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
My wear indicator light has come on for my front brakes and I wanted to check the disc thickness to see if I needed new discs at the same time as the pads.
Thanks |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
I dont know, they will test the brakes if they pass, they pass but if your pad thickness alarm is on thats another matter |
But the dealers are keen to check it for you |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Minimum disc thickness for the front is 31mm
For MY18 JLR spec
Yes, it's marked on the outside edge |
Thanks all.
