Home > Maintenance & Mods (L322) > Front and Rear Differential Change… How? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Have you priced this up yet David? |
19th Jan 2022 11:56pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
I’ve got everything here already other then the driveshafts.
20th Jan 2022 12:01am |
Wow, you've done well there David... The last rear diff I priced up was £3k+ |
20th Jan 2022 12:03am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Might make for a bigger job in terms of refurbishing extra things you might find, but for the rear I would suggest dropping the entire rear subframe out and off the car, give you lots of access for everything .
20th Jan 2022 11:59am |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
Are the diffs in new casings or is it the inners that you are changing with new Carrier bearings? If it’s the inners you will need to set back lash and make sure the gears mesh correctly.
20th Jan 2022 3:52pm |
The new diff comes as a complete assembly other then the locking motor and gears thankfully.
20th Jan 2022 3:55pm |
The new unit:
20th Jan 2022 3:57pm |
That makes it much more straight forward even if it can be done in place it would be an idea of dropping the rear frame and changing all the bushes at the same time |
20th Jan 2022 4:11pm |
That’s a good point Pete. Will see how we go.
20th Jan 2022 9:06pm |
I’ve got the car in the workshop just now.
13th Feb 2022 1:39am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Hi David.
13th Feb 2022 9:14am |
Thanks Dave
13th Feb 2022 9:41am |
Thanks again for the advice, Dave.
13th Feb 2022 8:06pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
A rear open diff is heavy but the e-diff is even more so. My son and I swapped my original open diff for an e-diff without a hoist, using 2 jacks and timber to progressively lower then raise the diffs. Stretching the hubs far enough apart to get the half-shafts in without damaging the new seals wasn't much fun either. |
13th Feb 2022 11:22pm |
