![]() | Home > Maintenance & Mods (L322) > Front and Rear Differential Change… How? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Have you priced this up yet David? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
I’ve got everything here already other then the driveshafts. |
Wow, you've done well there David... The last rear diff I priced up was £3k+ |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Might make for a bigger job in terms of refurbishing extra things you might find, but for the rear I would suggest dropping the entire rear subframe out and off the car, give you lots of access for everything |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
Are the diffs in new casings or is it the inners that you are changing with new Carrier bearings? If it’s the inners you will need to set back lash and make sure the gears mesh correctly.
The new diff comes as a complete assembly other then the locking motor and gears thankfully.
The new unit:
That makes it much more straight forward even if it can be done in place it would be an idea of dropping the rear frame and changing all the bushes at the same time |
That’s a good point Pete. Will see how we go.
I’ve got the car in the workshop just now.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Hi David.
Thanks Dave |
Thanks again for the advice, Dave.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
A rear open diff is heavy but the e-diff is even more so. My son and I swapped my original open diff for an e-diff without a hoist, using 2 jacks and timber to progressively lower then raise the diffs. Stretching the hubs far enough apart to get the half-shafts in without damaging the new seals wasn't much fun either. |
