Home > Wheels & Tyres > Pirelli pncs truth or scam?
Kot
My last post's were about tyres, and thought I would share this other interesting point or is it a scam? that came out of those threads.
Slow puncture 22" Pirelli with 6mm tread left, the nail was in a good place to be repaired (confirmed by tyre mechanic).
When I came to collect, I was told they had cut away the PNCS foam, drilled the hole and twice tried to glue the repair patch.
so good so far.
Twice they said this glue did not work and tyre leaked, they suspect its reacting with the glue from the foam left behind as it bonded with the underside of the tyre?
They gave up and said I needed a new tyre as it would be dangerous to continue with this repair.
(I was thinking afterwards, surely they could rough up the rubber a little if that was true, to remove old bonded glue? a bit like you do with inner tubes with sand paper etc)
I saw the tyre, saw the drilled hole and where the foam had been cut away from underside of the tyre.
With hindsight, I am thinking fool, should have taken the old tyre for 2nd opinion but what do I know, certainly not a rubber expert Rolling with laughter and then time was pressing so just left him to order a new tyre.
Has anyone heard of this issue before with Pirelli PNCS tyres?
I think next tyre stop in the future will be with the likes of ATS etc 2018 SE SDV8 4.4 Byron Blue
Post #623476 12th Feb 2022 8:18pm
Sounds fishy to me....... Rolling Eyes
Post #623493 12th Feb 2022 11:15pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Ditto on the fishy. They are more difficult to repair due to the foam inserts, but Will clean up with a bit of good old elbow grease and brake cleaner or similar. Thumbs Up
Post #623519 13th Feb 2022 9:20am
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
As Diesel Dave stated takes a bit more effort to clean and prep but we do plenty of them. But then again we are not a back street concern 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #623582 13th Feb 2022 4:26pm
TJH1985
We’ve had one repaired without any issues, damn thing picked up a screw 150 miles old.
We were on holiday and the only place we could find was a place that specialised in repairing tractor tyres etc they had it repaired and balanced in no time for £8 couldn’t believe it!
Rubber blocks on their jacks etc was a nice outfit, they even hid the balance weights behind the spokes. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #623590 13th Feb 2022 5:05pm
JayGee
Any adhesive used to stick the foam insets will by definition not impregnate the rubber of the tyre so it's hard to see how this could be an issue. 2012 TDV8 Vogue (L322)
Post #623597 13th Feb 2022 6:06pm
