Home > Maintenance & Mods (L322) > Gearbox Oil change
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Gearbox Oil change
Anyone know where I can get a gearbox megaflush near Manchester UK ? RR owner
Post #623455 12th Feb 2022 5:42pm
Mikey
Henshall Engineering Thumbs Up
Post #623461 12th Feb 2022 6:19pm
Old-un
Thanks seem knowledgable Just Emailed them for a quote. RR owner
Post #623475 12th Feb 2022 9:18pm
DrRob
Or Bodsy on your driveway
What’s App him on 07770638023
He’s a busy guy but extremely good at his job Thumbs Up Bow down
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623508 13th Feb 2022 9:12am
darrenm
https://www.facebook.com/UpdatesByBodsy/
Post #623514 13th Feb 2022 9:41am
dkatwa
Ball park, how much would a gearbox megaflush cost? I am in NW London
Cheers
deepak
Post #623982 17th Feb 2022 1:26pm
dkatwa
Just to add, thinking seriously about buying a 5.0 SC 2012 or so in the next two months....
d
Post #623983 17th Feb 2022 1:31pm
Old-un
Latest quote was £450 for an oil change but I'm not sure if that includes a flush but will find out RR owner
Post #623992 17th Feb 2022 2:58pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
If it helps, I've been quoted just over 500 for a full flush, as well as transfer and both diff oil changes. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #624023 17th Feb 2022 9:30pm
JayGee
A standard gearbox service inc diff and transfer box fluids cost me way less than that at an auto gear box specialist. 2012 TDV8 Vogue (L322)
Post #624051 18th Feb 2022 8:13am
dkatwa
Thanks JayGee...sounds reasonable if it includes a full flush....is this from an indy?
Post #624059 18th Feb 2022 10:35am
JayGee
Not a full flush. Just what drains out and a refill + filter change as per recommended by the gearbox manufacturer.
Any automatic gearbox repair specialist will do this - it's a ZF gearbox and not a JLR gearbox. 2012 TDV8 Vogue (L322)
Post #624061 18th Feb 2022 10:47am
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I’ve just had mine done on Thursday and it cost me £500 for a mega flush both axles and the the transfer box. Well worth it 👍
Post #624742 25th Feb 2022 6:11pm
JayGee
Cost me £350 for normal service, diff and transfer box oil change - what is worth the extra £150? 2012 TDV8 Vogue (L322)
Post #624746 25th Feb 2022 7:14pm
Simran0211
Mega flush the difference is that with a normal flush the old oil in the torque converter stays in there fresh oil is added and away you go but the old oil then mixes with the new fresh oil. It’s like changing the oil in the engine but not changing the oil filter.
The mega flush is slightly different where the new oil is pumped into the gearbox under pressure and the machine sucks the old oil out this now you have the gearbox and torque converter filled with fresh oil.
Hope this helps
Ps I had a after thought the filter in the gearbox hasn’t been changed but to do the job properly I would change the filter before Bodsy turns up then you know it’s all good 👍 😊
Post #624748 25th Feb 2022 7:24pm
