Home > Maintenance & Mods (L322) > Gearbox Oil change
JayGee
I know what the megaflush does but what advantage does this have over a standard service in practical terms (which changes most of the oil volume). Does a small % of old oil cause a problem? As a normal service also includes changing the filter it's not the same as doing an engine oil change without changing the engine oil filter. I know 'megaflush' sounds like a good thing but I've yet to hear why an autobox needs flushing (esp as it's not recommended by ZF)? 2012 TDV8 Vogue (L322)
Post #624750 25th Feb 2022 6:59pm
Mikey
Simran0211 wrote:
The mega flush is slightly different where the new oil is pumped into the gearbox under pressure and the machine sucks the old oil out this now you have the gearbox and torque converter filled with fresh oil.
A "Mega Flush" procedure isn't recommended by ZF, for this exact reason. Not all flushing machines are created equally...
Too much pressure/suction WILL cause damage, but not all machines will cause damage. The cheaper machines have no way to regulate the flow or pressure of the new oil
The top end machines measure flow, pressure and temperature of the outgoing oil, and automatically replaces it with new oil at the same flow and pressure, removing the risk of damage
So, when it comes to a flush, don't be afraid to ask questions Thumbs Up
Post #624758 25th Feb 2022 8:21pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Finished that Defender yet? Razz
Mr. Green 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #624763 25th Feb 2022 9:23pm
Mikey
No. Its putting up a fight Evil or Very Mad
Post #624765 25th Feb 2022 10:33pm
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Yep exactly what mikey said 👍👍
Post #624771 26th Feb 2022 4:46am
kevinp
I had my car done at an official ZF service centre because they change the filter as well and was thinking they somehow did something special.
They got about 6 litres of fluid changed. If I knew they only did what I could have done myself I wouldn't have taken it to them.
Post #624783 26th Feb 2022 9:13am
Mikey
https://www.facebook.com/100040967200185/posts/718783072830593/
Post #624897 27th Feb 2022 11:39am
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Very Happy Bodsy coming to me April, going for the ' Full Monty ' RR owner
Post #625153 2nd Mar 2022 4:13pm
