Home > Maintenance & Mods (L322) > Handbrake Shoe Replacement Issues
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I replaced the handbrake shoes the other day. I had no issues afterwards but rarely check whether the handbrake actually holds the car on a slope.
Off to the MOT this morning so thought I should try the bedding in procedure. Everything seemed fine until I put the handbrake on at the MOT garage.
Lots of unpleasant noises from the rear end and pinging from the dash telling me I had a parking brake fault.
C1A46-64 Mismatch between motor drive current and resistant force.
Had to drive home with a clear issue, particularly on one side. Found the upper rear side of the new shoe completely worn down but no real idea about what had gone wrong.
Aside from possibly getting the adjuster wheel between the bottom of the shoes facing the wrong way everything appears okay.
Any ideas what I should be looking for?
Post #623389 12th Feb 2022 10:14am
kevinp
Blimey Mike that is a mess.
Did you remember to adjust the shoes tight up to the drum and then back them off about 6 clicks?
Post #623397 12th Feb 2022 11:23am
I’m always surprised handbrake shoes wear on cars, why should they, you only apply the handbrake when the car is stationary so how come they wear?
Or are a lot of cars driving round with badly adjusted handbrakes wasting fuel. Question
Post #623399 12th Feb 2022 11:34am
Mike Edwards
I followed the workshop manual that says to back them off 8 clicks.
I suspect the EPB bedding in procedure meant the EPB module ran out of adjustment and slipped off the end of the gear which is what is making the noise.
Now I am unable to release the handbrake, either via the red loop under the cup holder or the loop in the boot. Probably not pulling hard enough but can’t pull any harder.
Post #623402 12th Feb 2022 11:45am
JayGee
Ah the joys of drum brakes....
8 clicks sounds a lot. When I was looking at some videos of shoe replacement it was back it off just enough to free the friction which was also how I remember doing it on old cars. 2012 TDV8 Vogue (L322)
Post #623404 12th Feb 2022 12:03pm
kevinp
I know it doesn't help now but when I replaced mine I didn't do the reset and it holds perfect.
Hope you can sort it.
Post #623414 12th Feb 2022 12:56pm
JayGee
Just read the bedding in procedure and it looks both complicated and impractical unless you have access to a private road. 2012 TDV8 Vogue (L322)
Post #623422 12th Feb 2022 1:14pm
Mike Edwards
Wish I hadn't tried the bedding in procedure. What sort of idiot writes a process that allows the controller to wind the adjuster off the end of the shaft?
Post #623456 12th Feb 2022 4:44pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
As you said it yourself,
the adjuster appears to be fitted the wrong way round.
From your picture, see how it is pushing the spring upwards, thus pushing the top of the shoe onto the drum.
Link; https://workshop-manuals.com/landrover/l32...handbrake/ L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #623516 13th Feb 2022 8:44am
JayGee
Despite my many years of experience with fitting various brakes to various cars this is just another reason I'm going to let a LR specialist garage do mine when they need it. 2012 TDV8 Vogue (L322)
Post #623524 13th Feb 2022 9:31am
Mike Edwards
As far as I can tell the orientation of the adjuster is for consistency rather than operation. Even turning it around the other way the spring still gets pushed up. it is the pressure from the spring on the adjuster dial that ensures that it doesn't come undone in normal operation.
Post #623545 13th Feb 2022 11:26am
kevinp
Yep, well said Mike.
Post #623550 13th Feb 2022 12:05pm
Mike Edwards
Sadly it appears my EPB module is jammed solid and refuses to release. This is going to get expensive!
Post #623952 16th Feb 2022 10:16pm
kevinp
Have you got an IID tool? I know I've seen an instruction on there for the handbrake. See if you can possibly do a reset?
Post #623957 16th Feb 2022 10:49pm
Mike Edwards
I've tried all the options on the IID Tool. They all fail.
It appears the internals of the EPB module are jammed solid.
Post #624038 17th Feb 2022 10:30pm
