Home > My Range Rover > Run for the hills? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
As yours is the same age and engine as mine ...
8th Feb 2022 3:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7828 |
Do they still have the oil cooler issues on the L405? Sounds like that could be leaking….
8th Feb 2022 3:35pm |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 256 |
Sounds a familiar story to me. Sold my lovely D4 because of the dreaded crank issue and dipped my foot in the L405 world only for it to turn bad
8th Feb 2022 3:38pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
I believe so. I'd be asking them to check Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
8th Feb 2022 4:25pm |
I think so. Would explain why the oil cooler on mine was replaced just before I owned it. What do I put here then? |
8th Feb 2022 4:30pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Oil cooler is a problem on the 4.4 in the L322, L405 and L494.
8th Feb 2022 5:52pm |
tet Member Since: 02 Feb 2022 Location: UK Posts: 3 |
A local specialist has diagnosed the problem to be high pressure fuel pump related. |
11th Feb 2022 2:08pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
First thing I did on mine was clear codes and change the battery for a new one. Its like a 'clean start' for a new owner. I appreciate this will not sort mechanical issues but it might just stop you chasing your tail on other warnings.
11th Feb 2022 5:40pm |
