![]() | Home > My Range Rover > Run for the hills? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
As yours is the same age and engine as mine ...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
Do they still have the oil cooler issues on the L405? Sounds like that could be leaking….
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 263 ![]() ![]() ![]() |
Sounds a familiar story to me. Sold my lovely D4 because of the dreaded crank issue and dipped my foot in the L405 world only for it to turn bad |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I believe so. I'd be asking them to check Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
I think so. Would explain why the oil cooler on mine was replaced just before I owned it. What do I put here then? |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Oil cooler is a problem on the 4.4 in the L322, L405 and L494.
tet Member Since: 02 Feb 2022 Location: UK Posts: 3 ![]() |
A local specialist has diagnosed the problem to be high pressure fuel pump related. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
First thing I did on mine was clear codes and change the battery for a new one. Its like a 'clean start' for a new owner. I appreciate this will not sort mechanical issues but it might just stop you chasing your tail on other warnings.
