Home > Technical (L322) > Starter motor replacement L322 TDV8 |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
That will be a quick and dirty should the car fail to crank or to prove the hypothesis, Grame's solution is more elegant once this proves to be a permanent solution. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
9th Feb 2022 11:46pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2541 |
I bought one of these https://www.ebay.com.au/itm/393501028384 and triggered it using the original solenoid trigger wire. The idea is that the little relay draws minimal current through the trigger wire compared with the starter solenoid. I made-up 2 short HD leads, one to go to the battery power terminal on the starter solenoid and the other to the solenoid's trigger bolt with appropriate size ring terminals. The relay is temporarily held to the solenoid using multiple/redundant cable-ties but I intend making a bracket to bolt it somewhere. I sealed the relay before fitting it. |
10th Feb 2022 12:54am |
Thats what I was thinking also, did you splice near the air box or further downstream? any pics?
10th Feb 2022 10:03am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 759 |
In Australia we were doing this in the 1960s to English cars, lucas them days. RR 2005 4.4 petrol
10th Feb 2022 11:42am |
I just took the trigger wire off the solenoid and used it to trigger the small relay, which also needs an earth wire. The original trigger wire is more than adequate for the small current required for the relay. |
10th Feb 2022 8:30pm |
Thanks for that, how is it working for you? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
11th Feb 2022 8:20am |
Mine's starter wasn't misbehaving but now seems quicker at jumping to life. The task was to save the solenoid contacts burning from inadequate engagement speed and engaged pressure before the contacts deteriorated much more. |
11th Feb 2022 10:32am |
good call! SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
11th Feb 2022 10:56am |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 |
Graeme, I’m going to do this mod using the same style of motorcycle relay as you. However, whilst I get my head around the wire lengths and connections I need to purchase for the install, I’d be really grateful of any advice you can offer on the following:
13th Apr 2022 9:29am |
I used the main starter feed for the relay feed.
13th Apr 2022 11:38am |
Graeme - legend! Thanks for coming back so quickly and really helpful too!
13th Apr 2022 12:18pm |
If the resistance of the solenoid between the trigger terminal and earth is measured then the maximum current draw can be calculated but I suspect that it wouldn't be more than 15A but probably less than 10A. There won't be any surge from the alternator during cranking as the PCM waits several seconds to allow the engine to get up to speed before loading the alternator, as seen when the voltage is monitored.
13th Apr 2022 8:53pm |
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 |
Had a question from a member about the new cable I fitted, so a few photos attached.
12th May 2022 11:20am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
so Shaun, you went onto the backplane of the starter relay, or traced out the wire and joined into it there.... is that the black blob of insulation, on last pic? i can manage the cable run ok, if i just know where to interrupt the suspect wire itself. |
12th May 2022 11:49am |
