Home > Maintenance & Mods (L322) > Rear tyre wear - offside inner edge |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Soak everything in penetrating spray for a few days Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Feb 2022 8:45pm |
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 |
Haha. I am amazed at how corroded everything is under there. Very crusty. I see rustproofing in my future. |
5th Feb 2022 8:47pm |
Ben84 Member Since: 13 Dec 2018 Location: Cornwall Posts: 80 |
I recently had the same issue, mine was due to worn rear hub bushes. I had both
6th Feb 2022 5:49pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Usually the bushes I changed all the rears on mine at 95k and again at 190k didnt see the point in replacing only the one that was failing and it drives like a dream after |
6th Feb 2022 10:08pm |
Sounds sensible to renew the lot really. What sort of time DIY would it take? Is there a decent 'how to' anywhere you can recommend? Did you go for new arms or just replace bushes etc? The ones on there look rather crusty as does the subframe itself! |
6th Feb 2022 11:21pm |
Am I missing anything if I change everything in the top and bottom pic and the two hub bushes on the middle pic, on both sides of the car, is that all of the rear suspension sorted?
7th Feb 2022 6:10pm |
