![]() | Home > Maintenance & Mods (L322) > Rear tyre wear - offside inner edge |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Soak everything in penetrating spray for a few days |
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
Haha. I am amazed at how corroded everything is under there. Very crusty. I see rustproofing in my future. |
Ben84 Member Since: 13 Dec 2018 Location: Cornwall Posts: 88 ![]() ![]() ![]() |
I recently had the same issue, mine was due to worn rear hub bushes. I had both
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Usually the bushes I changed all the rears on mine at 95k and again at 190k didnt see the point in replacing only the one that was failing and it drives like a dream after |
Sounds sensible to renew the lot really. What sort of time DIY would it take? Is there a decent 'how to' anywhere you can recommend? Did you go for new arms or just replace bushes etc? The ones on there look rather crusty as does the subframe itself! |
Am I missing anything if I change everything in the top and bottom pic and the two hub bushes on the middle pic, on both sides of the car, is that all of the rear suspension sorted?
