![]() | Home > Technical (L322) > 2007 Supercharged Misfiring |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Could possibly be the petrol your using mate I guess. I've noticed that with mine. When I've used the regular e10 petrol either on the bike or in the range, in the cold they seem to start up slightly lumpy but after a short while it seems too sort itself out but soon as they run on e5 they start up with no issues. Maybe try some octane booster
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Meant to add it’s got E5 in the petrol tank and LPG.
Pretty much elimates the fuel if its doing it on lpg. Tried cleaning the maf with some electrical cleaner?
I did just after I got it when I was going through everything else on it. Certainly haven’t done it recently so will give it another go |
If that don't work, pm me your home address and I'll send my one up to you so you can test it at least and see if it works.
Thanks Allen |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
same as allen i use ipa in a spray bottle and then drop it on a heater or rad to dry i fitted a k and n filter so do mine every month to clear away any oil that may come from the air filter new vehicle purchase
Unplugging the MAF will cause the car to run in limp mode but it should stop it doing anything that would be MAF related I’d have thought.
Try clearing the fault codes, disconnect the maf, then start up as it should throw up it's now got a maf issue so hopefully the other ones won't return.
The LPG has its own injectors and everything so there’s nothing shared between the 2 fuels which is handy for fault finding.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Mine had a similar misfire on starting when it was over filling on valve saver fluid, something to look at.
That’s an interesting point on the valve saver fluid.
Just noticed that I'd used a lot more than usual and it was over dosing by a factor of 3, I think it was just getting sucked in on cold start up as it was fine if the engine was still hot. Since I've recalibrated its got no misfires on starting. (its just a drip feed system under vacuum with the inlet after the throttle butterfly, I have a slipstream of petrol above 2900rpm, done 60k on lpg and all healthy) |
I think the system on mine is pumped rather then vacuum fed. There’s a little unit mounted to the front of the battery box next to the reservoir for it.
