Home > Technical (L322) > Code P0088-00
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Code P0088-00
Car running fine then, cuts out and the usual faults appear! Suspension lowering, limited gears, engine system fault, HDC inactive………………. Switch off, reboot car runs fine until the next bong!
Any ideas…………….. 2014 vogue se
Post #622374 3rd Feb 2022 7:59pm
bishbosh10
Random faults?
I am going to wager battery. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #622495 4th Feb 2022 7:54pm
chefkenmore
Unlucky Bishbosh
Brand new battery on Wednesday! 2014 vogue se
Post #622501 4th Feb 2022 8:50pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
High Fuel Pressure. Either fuel line, pump or sensor fault.
Post #622506 4th Feb 2022 9:38pm
Mikey
Usually sensor. Done a few over the years Thumbs Up
Post #622508 4th Feb 2022 10:33pm
Dolphinboy
@mikey Thumbs Up
Post #622531 5th Feb 2022 9:49am
chefkenmore
Thanks guys appreciate that, could the fuel filter also be part of the issue? 2014 vogue se
Post #622830 7th Feb 2022 9:25am
dhallworth
A friend of mine had something similar happen when his alternator was in the early stages of failing. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #622835 7th Feb 2022 10:00am
chefkenmore
Is it a whole rail or just a switch Mike? 2014 vogue se
Post #622850 7th Feb 2022 1:35pm
Mikey
Pretty sure you can't buy the sensor alone, only comes as part of the rail
That said, you can remove the new sensor and fit to the engine easy enough, without stripping the top half of the engine Thumbs Up
Post #622909 7th Feb 2022 7:59pm
chefkenmore
Thank you 2014 vogue se
Post #622914 7th Feb 2022 8:50pm
chefkenmore
Fault rectified! Was indeed the fuel rail sensor!
Thanks for the pointers guys, and a brand new MOT to boot! 2014 vogue se
Post #622973 8th Feb 2022 3:07pm
chefkenmore
Post #622974 8th Feb 2022 3:12pm
