Home > Maintenance & Mods (L322) > Poor mpg… what to check? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Evening all. After a reset of the cars trip computer following a battery disconnect, I notice the mpg is poor.
4th Feb 2022 9:16pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3227 |
Don’t trust the mpg on the trip readout to be accurate esp after a reset. The only way to be sure is to divide distance between fill ups with gallons of fuel put in. 2012 TDV8 Vogue (L322) |
5th Feb 2022 6:26am |
Cheers JayGee
5th Feb 2022 7:17am |
That’s a good shout. There’s a great thread on dpf and regens so I’ll look at what to monitor on my IIDTool to see my soot level. My general drives include stints where the dpf regen should kick in, so expect my level to be low. This may give a clue and worth a check. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
5th Feb 2022 7:20am |
I forgot to mention, I checked my brakes too last night.
5th Feb 2022 7:25am |
What’s your miles remaining on the trip after a fill? On light load a partially blocked intake or dpf won’t kill mpg as there is not enough airflow for a restriction to be significant. There is input from GPS as the nav has a calibrate after tyre change function in the settings. Are you running stock tyre sizes? 2012 TDV8 Vogue (L322) |
5th Feb 2022 9:00am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
The DPF regen frequency theory affecting MPG is a good one but I can demonstrate it's not having an effect - apols I don't want to seem contradictory!!
5th Feb 2022 11:02am |
Once did a brim to brim after 200miles mainly on the M-way and got 32mpg. 2012 TDV8 Vogue (L322) |
5th Feb 2022 11:55am |
5th Feb 2022 12:00pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 359 |
I’m only getting 24/25 mpg but short runs of circa 10 miles so I would suggest about right. These are measured and recorded brim to brim. Live on side of a hill so going one way it’s 1/2 mile climb fro cold that unfortunately is the most common journey. Other car is a Kia Niro and it fluctuates by up to 10 mpg depending on journey.
5th Feb 2022 12:24pm |
I would suggest any real mpg north of 25mpg on mixed driving is not bad given a 4.4 V8 pulling 2.7tonnes….
5th Feb 2022 12:32pm |
I’ll fill up today, and will check. I used to get over 500 remaining on a tank so will see soon. That’s a good point regarding airflow. My journeys have been light on the throttle and not using the big turbo.. unless it’s really bad of course I’m not on stock… my rolling profile is larger than stock, but I have adjusted as best I can in the IIDTool. 60mph shows 58 on the dash. I have been running on these tyres for months and hadn’t noticed a change in fuel consumption. But I will be mindful as I may not have noticed before now… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
5th Feb 2022 12:49pm |
I cleaned the MAP sensor, but do have a spare. I’ll brim the tank and see what I get, then swap the MAP sensor to see if that makes a difference. It could be faulty. I didn’t think the MAF sensors needed cleaning? They are behind the filter so should remain fairly clean? It’s also interesting to see your real world mpg… a fair bit lower than the reported?!?! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
5th Feb 2022 12:55pm |
Interesting about your shift point comments… I do notice that my gearbox doesn’t lock the torque converter in the lower gears. When cold, they do this to help warm the oil, but mine still does it after warmed up. I am looking to get a fluid change in the next month because of that… However most of my (albeit limited) test runs have been at speeds where the TC is locked so am discounting that for now. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
5th Feb 2022 12:59pm |
