![]() | Home > Maintenance & Mods (L322) > Poor mpg… what to check? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
So I don’t believe I have a leak as I cannot see any signs of misting, and there are no warning. But I will have a better look in the coming weeks.
Forgot to mention… a brimmed tank registered a range of 460 miles. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
460 is quite low. Least I’ve had is 550 and most 630. What tyres are you on ? 2012 TDV8 Vogue (L322) |
I’m on 285/45 R22 which is 3.5% larger than stock.
Btw, appreciate the help and suggestions! |
285/45 R22 are 7% over stock (255/55 R19 / 255/50 R20) on the L322. Could be pushing it for optimal gearing vs engine torque curve. 2012 TDV8 Vogue (L322) |
Ah, yes the size I compared against was incorrect… I am indeed 7% larger than stock!
Engine will be turning lower revs per road speed and engine may not be at max efficiency and or as said earlier the gearbox is interpreting the higher effective gearing / load as a hill or a tow and holding higher than optimal revs. Also wider profile tyres generally have more rolling resistance and if they are budget tyres this also means they are less than optimal in this parameter.
So its been a few months since i last updated this thread and thought I’d revive it.
So after a 240 mile round trip with mostly motorway driving with cruise control set to 75, I averaged 26mpg.
Was this mpg worked out from fill to the brim vs actual miles or the trip display. If your tyres are bigger than stock both your miles traveled and trip mpg will be under displaying. Over 75mph the mpg drops to sub 30mpg on mine and you also have cheap tyres which will likely have extra rolling resistance so 26mpg is not that far off what I’d expect.
Thanks JayGee
I am planning on swapping the tyres on my car… at some point.
That other person was Range Rover L322… ![]() As requested, these are my calculated results. One fill up was missed… but still gives an indication of what my car is running at.
