Home > Maintenance & Mods (L322) > L322 2005 4.4 m62 Coolant trouble? |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
Have you taken the small top hose off the radiator? I can’t recall if it’s on the left or right on the M62, but run it like that and hopefully it’ll bleed. Obviously put it back on afterwards!!
31st Jan 2022 7:30pm |
Sigmundreder Member Since: 29 Sep 2021 Location: Oslo Posts: 36 |
Thanks! Thats a good tip! I have not done that yet.
1st Feb 2022 7:24am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
My hose did the same mate. Try a new expansion tank cap but I also had to get a new hose because the old one was soft. |
1st Feb 2022 8:58am |
Expantion tank cap and bleed screw brand new.
1st Feb 2022 9:00am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Which cap did you get ?? 140 or 200 ?? Seems there is a debate about the correct 1, I'm having issues with mine it had a140 o it when I got it seems it should be 200 for the m62 4.4 petrol.
1st Feb 2022 3:46pm |
200
1st Feb 2022 4:43pm |
https://www.fullfatrr.com/gallery/albums/u...ooling.JPG
1st Feb 2022 5:35pm |
Cheers Dave!
1st Feb 2022 6:15pm |
So came in to the garage this morning, and the upper radiator hose going in to the waterpump was completely flat.
2nd Feb 2022 7:30am |
I think you still have air in the system even with the soft hose. Have you tried bleeding it with the front end as high as you can get it like on some ramps? |
2nd Feb 2022 8:16am |
https://www.ebay.co.uk/itm/Cars-Coolant-Va...635-2958-0
2nd Feb 2022 8:56am |
The front of the car has been parked on an incline.
2nd Feb 2022 9:58am |
Drain everything today.
5th Feb 2022 6:20pm |
Its air locked, you need the kit I suggested to vacum fill it |
5th Feb 2022 6:45pm |
