Home > Maintenance & Mods (L322) > Water in spare wheel well, but unusual...... |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 578 |
I had the same symptoms,
4th Jan 2022 1:10pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I agree, possible tail gate seal. Water will track along the rear panel & fill the spare wheel well.
4th Jan 2022 1:23pm |
TDV8_NCS Member Since: 03 Nov 2021 Location: Warrington Posts: 7 |
It was the same for me. The water is getting in at the top of the boot. The water is getting in the U section of the rubber seal that fits over the metal and works its way around to the sides. If you pull the seal off at the top corner you will see a gap were the metal joins in the corner. This allows the flowing water to go inside the pillar and work its way down the inside getting into the boot without getting the carpet wet, or anywhere near the electrics in the corner. I didn't get a new seal, I just put a bit of silicon sealent inside the rubber U section to seal it to the metal when I pushed it back on and this seems to have solved it. Believe me, I had tried everything before this, a really was at an end of all the things I could think it could be.
4th Jan 2022 6:24pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Thank you gents.
4th Jan 2022 6:56pm |
Big thanks to you TDV8_NCS
31st Jan 2022 7:03pm |
Glad to here it worked. I still check mine on a regular basis and so far so good. This forum is full of good information from people who have been there and done that.
31st Jan 2022 8:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Glad it got sorted sir |
31st Jan 2022 11:44pm |
