Home > Maintenance & Mods (L322) > Harsh ride!! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3195 |
When I serviced mine a few weeks back I accidentally did a 'Vehicle Reset' (instead of service reset) via my GAP IID tool and I could swear the ride quality has improved since then as I was also not that happy with the rather harsh ride. 2012 TDV8 Vogue (L322) |
31st Jan 2022 3:27pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Perhaps a shock is seized. Or if you have active dynamic suspension it’s probably just the loom. It was reall noticeable on my when the loom went. The ride was shocking 🤣
31st Jan 2022 3:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
obvious guess- are the tyre pressures correct? ... - .- -.
31st Jan 2022 3:42pm |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
I have tried different tyre pressures, I have 275/45 R20 tyres and have tried the PSI at 1 below what the door card states, I've tried them soft and hard but it doesn't really make much difference.
31st Jan 2022 3:57pm |
If the loom was faulty would I get a light on the dash or fault on the GAP tool? |
31st Jan 2022 3:59pm |
you should but i would check the wiring on top of the front struts and see if theres any chaffing ..
31st Jan 2022 4:12pm |
The my GAP IID tool didn't show a wiring fault that was picked up by a LR specialist with their workshop diagnostics. The wiring to the struts is pathetic and seems to be a common fail point. 2012 TDV8 Vogue (L322) |
31st Jan 2022 4:26pm |
Same here as JayGee. Mine did not have a fault registered, none displayed on the car either. Air suspension will still go up and down no problem. The air suspension isn't directly related to the shocks so it will still work. The way the know it is that the ride is harsh...
31st Jan 2022 4:43pm |
Yes good point, that is a bit of an odd size tyre. Circumference difference isn't that bad actually, but still a rather odd size. As part of a combination of factors I bet that doesn't help either. |
31st Jan 2022 4:48pm |
The active suspension system must factor in a predicted compliance of the unsprung mass which is a combination of the air shocks and the tyres. If you fit a non standard tyre wall with less compliance I would have thought the system may struggle to compensate. Even different tyre types may not help hence possibly why certain tyres are recommended ? 2012 TDV8 Vogue (L322) |
31st Jan 2022 4:58pm |
So I have checked the wiring on the top of the struts up front, took off the dampers and unplugged them, all appears ok no chaffing etc. Not had chance to check the rear wires yet.
31st Jan 2022 5:30pm |
An unbalanced or out of round tyre will also I suspect not play well with the system. 2012 TDV8 Vogue (L322) |
31st Jan 2022 5:40pm |
I thought that as well but in an effort to rule that out I had the wheels re Diamond cut and balanced less than a month ago. |
31st Jan 2022 5:56pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i had an issue with mine you would go round a corner with a bump in it and the back end would skip (That is what it felt like) like the suspension was too hard. any how took both rear shocks off one was new (Bilstein) the other original and leaking. replaced that and all good ever since. looked through the history the new one at the time was 9 months old to get it through a failed MOT, which was when i purchased it. 2012 Vogue 4.4 TDV8 - Current
31st Jan 2022 6:10pm |
