Home > Technical (L322) > Urgent adviee needed , please help ! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3248 |
You mean the oil return pipe from turbo to sump? This should definitely be clear otherwise the oil can't circulate through the shaft bearings. 2012 TDV8 Vogue (L322) |
29th Jan 2022 10:25am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
No pal i mean the crank case breather on top of the left hand side of the engine , will be checking the return next |
29th Jan 2022 10:40am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7805 |
I imagine you could just take the filter bit out, that’s solid, and see how it runs.
29th Jan 2022 10:43am |
Think im guna have too pal |
29th Jan 2022 10:44am |
Pretty sure that will sort it mate. Get a later vortex one ordered for a BMW…. Not Land Rover or you will get the crappy design you already have.
29th Jan 2022 10:50am |
Like this, most folk change the whole unit, but you can just get the vortex bit and cut some plastic tabs and fit to yours.
29th Jan 2022 11:02am |
Ordered a new one but cant get it till nay unfortunately |
29th Jan 2022 11:27am |
Ive run the engine till warm and there is only blueish smoke when i press the throttle and rev to 2/3k at idle theres none at all , im convinced the turbo is ok |
29th Jan 2022 11:58am |
Probably chucking the crud out. Filter tends to always gets missed when servicing at a garage, and causes all sorts of issues. That’s why BMW changed the design, but that was after they had sold Land Rover.
29th Jan 2022 12:04pm |
Will give it a good run tomorrow and fingers crossed, the problem will be srted |
29th Jan 2022 12:09pm |
I fitted a K&N air filter element too, which I get the pros and cons of these things, but that meant the engine cover didn’t have to come off at all when servicing…. Unless you wanted to check the air filter…. 2011 Range Rover Vogue SE 4.4 TDV8
29th Jan 2022 12:32pm |
Air filter is ok 👍 |
29th Jan 2022 12:37pm |
A blocked crank breather can force oil out of the turbo seals (and cause smoke) as it pressurises the return to the sump. Common issue on old diesel cars where sooty blowby gases mixed with oil and water vapour create a nice black tar. 2012 TDV8 Vogue (L322) |
29th Jan 2022 12:44pm |
Ok thats helpful info , as above , instict / experience tells me the turbo is ok and hopefully with the breather renewed the residue in the exhaust will burn off , if not i have a new charger i can fit anyway |
29th Jan 2022 12:48pm |
