![]() | Home > Maintenance & Mods (L322) > Doing the Oil Cooler - Thanks to mm289! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’m planning a similar job JMC
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 774 ![]() ![]() ![]() |
It's been a constant stream of delivery couriers for about a week now. Just wanted to make sure that I had everything needed for the job, including contingencies.
Delivery arrived from Rob at Duckworths today and it's worth noting that the oil cooler gaskets have new part numbers, signifying an update / change to the original parts.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2556 ![]() ![]() ![]() |
Hopefully the new numbered gaskets are improvements. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 695 ![]() ![]() ![]() |
That was my point in an earlier post. |
Just want to add a +1 to this… I took it off as I am replacing pulleys and I must have just looked at it wrong as it broke that easily! ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Just an update on this after the best part of a month and a thousand miles from doing the job on New Years Day.
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
Brilliant, sounds like it's sorted |
Took the sump guard off today to check for any signs of leaks etc. After 18 months and 15,000 miles from doing the oil cooler gaskets, I'm happy to say it's still a clean bill of health. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
Good stuff!
EOD Steve Member Since: 13 Feb 2023 Location: Lincoln Posts: 221 ![]() ![]() ![]() |
I had a minor leak and my local indy diagnosed an oil cooler leak. 2012 MY.
jellmers Member Since: 30 Mar 2022 Location: Plymouth Posts: 9 ![]() ![]() ![]() |
Silly question but at these the correct size of the L322 4.4TDV8 (2011)??
The 70mm i/d is correct, but I ended up buying a single (1m) length to cut myself. In the end, I never actually used it and now at 72k miles, everything is still ok.
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 338 ![]() ![]() ![]() |
I did similar with a piece of brake pipe as a stent, detailed on this topic 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
