Home > In Car Electronics (L322) > blinking power button but screen blank
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
ive searched , ive read tons but not one thread on a blinking power button with a blank screen , any things to check before i go android ? cars an 06 SE
thanks
Post #621468 26th Jan 2022 4:52pm
bembo449
Just to add to this , what should be behind the NSR boot panel ? If something is missing that will explain why its not working , like a DVD player? I had vogue previously so unfamiliar with the lower spec models unfortunately
Post #621488 26th Jan 2022 7:42pm
mjdronfield
Really need pictures……
Make sure it’s all dry, and clean contacts/look for any broken pins in the connectors is what I’d do first I recon.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621490 26th Jan 2022 8:07pm
bembo449
cant provide any right now pal , sorry but if you imagine the flashing power button with a blank black screen , thats what i have , ive read / seen youtube vids where the LR logo is on screen with power button flashing and a poss cure for that but cant find anything where the screen is blank , the boot comp looks dry but as i said earlier , is there something missing from that area ? the BT module is there and the vertical silver box but nothing else and i cant find info on what the SE infotainment system should contain
Post #621494 26th Jan 2022 8:29pm
dhallworth
Usually if something breaks the fibre optic ring you’ll get an orange flashing light and the LR logo on the screen.
It’s a strange car as by 06 the only specs available were HSE, Vogue and Vogue SE.
What engine is in it? I wonder if it’s one that’s sat around before being registered. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #621498 26th Jan 2022 8:42pm
bembo449
Its a td6 pal ignition key is near gearstick too
Post #621505 26th Jan 2022 9:38pm
bembo449
[img]https://linksharing.samsungcloud.com/tA90dKzwjr1f
Hoping that link works , as there is an error trying to upload as a picture [/img]
Post #621709 28th Jan 2022 8:43pm
Chris1573
Take a look in the left hand panel in the boot, there is a "stack" that includes the Bluetooth module (on top) and then the amp, NAV CD etc. There is a fibre optic cable that loops to each one of these. If one of these fails then its breaks the circuit. You will probaby find if you pull the plugs some blue residue where water has run down the cables from a leaky window seal. If you can work out which one it is you can get use a biro to make a temporary bridge on the fibre optic cable and this will enable you to test if this is the issue.
In mine the BLue tooth unit was the issue and had corrosion in the plug and on the board. I bypassed it and everything came back to life. So I ordered a replaceent Blue tooth unit. L322 2007 TDV8 3.6
Post #621815 29th Jan 2022 5:59pm
bembo449
Ok pal , can you not see the link i posted? I think theres something missing from the boot compartment!? I reckon if i know what i will understand why i have my issue . . . Then jjust go android 😄
Post #621816 29th Jan 2022 6:03pm
Chris1573
Hi Bembo.
Looking at the picture it appears that the Navigation unit may be missing. However if the optical cables are bridged then the head unit should still work. If you follow the two thick white wrapped wires from the top module (bluetooth) do they go directly to the next module or is there a plug not connected. L322 2007 TDV8 3.6
Post #621932 31st Jan 2022 9:20am
bembo449
Ok pal , will look at that 👍
Post #621982 31st Jan 2022 4:00pm
bembo449
Right, ive looked at all the fuses ( i think ?) Tried looping the fibre optics , still nothing , anything else to look ?
Post #622084 1st Feb 2022 12:35pm
Shinner23
United States 2011 Range Rover HSE 5.0 V8 Santorini Black
Did you ever find out what it was?
Post #634662 15th Jun 2022 2:47am
mjdronfield
Bit of info here….
https://www.fullfatrr.com/forum/viewtopic.php?p=634738#634738
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #634749 15th Jun 2022 10:06pm
