![]() | Home > Technical (L322) > Squeaky wheel |
Sounds like run out on the disc to me. Had that on my last one. The run out causes the pads to return too far back into the caliper leaving them slightly loose and that's what causes the squeak. Like you say a quick dab on the pedal gets rid of it.
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
Presumably this is something that needs to go back to the garage to check? |
I don't know but assume so. To be clear there is no noise under braking, only after the brakes have been applied. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
mine did exactly this, took 1000 miles for them to bed in then all ok. |
Update: The problem has improved marginally over time and/or I've managed to highlight the cause more accurately. It seems to be worse when the wheel (drivers side) is under load - i.e. when turning. Any further ideas on causes chaps? |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Hmm, wonder if it could be to do with the caliper bolts altering the angle of the caliper until it's loaded?
