Home > Technical (L322) > Squeaky wheel
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Did they fit genuine pads? the squeak is usually caused by the material the pads are made from. Cheaper pads use lower quality materials. I would check the rear of the pads for a name stamp.
Post #62128 29th Apr 2011 5:50pm
mzplcg
Sounds like run out on the disc to me. Had that on my last one. The run out causes the pads to return too far back into the caliper leaving them slightly loose and that's what causes the squeak. Like you say a quick dab on the pedal gets rid of it.
Run out should be no more than about 10 thou which you can only test properly with a surface gauge.
HTH
Dom.
Post #62137 29th Apr 2011 7:32pm
rocksteadyeddie
HTH
Dom.
Presumably this is something that needs to go back to the garage to check?
Post #62422 2nd May 2011 9:23pm
rocksteadyeddie
I don't know but assume so. To be clear there is no noise under braking, only after the brakes have been applied.
Post #62423 2nd May 2011 9:24pm
Vogue
Re: Squeaky wheel
rocksteadyeddie wrote:
I recently had the pads and discs done on the front of my FFRRSC.
Since then the drivers side wheel squeaks periodically. When it does so the squeak is "solved" by applying the brakes - even quite gently. My immediate thought was either wheel bearing or rubbing pad (although I am not quite clear why this would squeak). Any ideas chaps?
p.s. I have a sound file but have no idea how to post it.
mine did exactly this, took 1000 miles for them to bed in then all ok.
Post #62424 2nd May 2011 9:29pm
rocksteadyeddie
Update: The problem has improved marginally over time and/or I've managed to highlight the cause more accurately. It seems to be worse when the wheel (drivers side) is under load - i.e. when turning. Any further ideas on causes chaps?
Post #80837 13th Sep 2011 11:18am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hmm, wonder if it could be to do with the caliper bolts altering the angle of the caliper until it's loaded?
I only mention it because I changed mine last week and some C*%$(%*$)£*)$(*£$*%$:::@"t had cross threaded the upper caliper bolt.
Either that or wonder if it's a faulty disc?
Post #80854 13th Sep 2011 12:12pm
