Home > Technical (L322) > Why TDV8 turbos fail
Page 5 of 6 <123456>
GraemeS
I don't have a picture at the moment but with the undertray removed the plug is clearly visible hanging down directly above the centre of the cross-bar on the subframe.
Post #620272 17th Jan 2022 10:11am
Zerocult
Spain 2007 Range Rover HSE TDV8 Java Black
I am going to explain my opinion given my experience as an RR owner.
Turbos fail for various reasons on this brand. Never forget that turbos are pieces and as such, they can break.
Causes to consider:
1. Long idle time of the car. It does not matter maintenance (trusted workshop or official service). The turbo actuators get stuck and cause the turbo to fail. With its corresponding power failure. The solution is to check actuators from time to time and ensure that they are lubricated with copper grease. Do not use oil or WD40.
2. High quality oil must be used and in periods of 8,000/10,000 km. The reason is because a good oil lubricates better. And that helps the oil and drain pipes of the turbos.
3. In normal driving operation. These models require uptime or engine idle. Until you can accelerate the car happily. Start the car and wait until the water temperature is at its optimum point, to burn the asphalt. And when turning off the car after a demanding drive, leave the engine at idle (2 minutes) so that the parts cool down properly and the turbo turbine slows down. (preventive measure according to LR).
4. The most important. LR at the time had the turbo actuators designed by the garret brand. They were much more reliable components than the current mounted ones. LR discarded these parts and chose to place "their model", since they know the method and cost of their turbo change procedure. We all know the result...countless cases of turbo failure. This idea at first is a headache for Land Rover. Cars under warranty that need to be fixed. But they are rubbing their hands at the cost of unsecured cars.
Post #620882 22nd Jan 2022 8:15am
JayGee
What part of the 'actuator'? If it's the waste gate on the exhaust side of the turbine I'd not put any grease on there at all nor should it need it.
Only use the oil specified by LR. Not just cheap oils but also very expensive pure synthetic oils don't deal with sludge very well.
Never drive any car hard (turbo or otherwise) until the engine is up to operating temperature. It's not the coolant temp on the dash either but the oil temperature. Assuming the turbo's on the 3.6 are watercooled and you are using the correct oil they shouldn't need a cool down period - this is only applied to early turbo charged cars which ran old mineral oils and no watercooling. Spin down time is also false unless you redline it and then switch off the ignition. A small turbine doesn't have much inertia and will spin down very quickly.
It would seem the whole turbo/EGR/intake setup on the 3.6 is a poor design not just the 'actuators'. Not sure about the built in failure to ensure workshop revenue - if so why did JLR replace the 3.6 with the 4.4 at the end of it's production run? 2012 TDV8 Vogue (L322)
Post #620924 22nd Jan 2022 12:00pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
northernmonkeyjones wrote:
pretty sure the following contribute:
EGR failure
running with a split turbo pipe
poor servicing regime, on milage not time, do it every 12 months without fail, sooner if you drive further.
only use good oils to minimum WSS M2C 913 B
blockage of the turbo oil feed pipe caused by sludge build up because the mechanics are only draining one sump plug not both.
running hot then not allowing time to cool before shutting down.
So there is a second sump drain plug? I only came across this recently on a really good YouTube video ("I did a 200,000 mile service on the cheapest 4.4 TDV8 Range Rover L332") and noticed this on one of the comments below only - the owner of video did not do this. The comment said that the second drain plug was at the rear of the engine, about an inch and a half from the subframe?!? And that this second plug drains the turbos?!? Does that sound correct?!?
Also: would you suggest injector cleaner added to fuel via tank fill or is priming the fuel filter while renewing OK?!? How do you prime the fuel filter?
I just received Rimmer oils and filters - are these generally OK?
Post #658103 28th Feb 2023 4:50pm
garyRR
The second plug can be seen sitting just above the subframe. It's a flanged bolt and is drains the turbo.
Not necessary, but some members like to drain it every other oil change. The challenge is that you'll likely get oil running all over the subframe and then onto the driveway.
No need to prime the fuel filter. The 4.4 TDV8 is self-priming. If you don't trust it, just cycle the ignition from off to on several times before starting the engine.
No need for injector cleaner. Just ensure you take the vehicle on a motorway run regularly - it allows the engine to get to full operating temperature and for the DPF to regen.
Also, every 1,000 miles and at service, remove and clean the MAP sensor (1x T20 screw on top of the donut).
I used to dump the oil but I now use the Draper vacuum pump that many members use, because there's no need for jacks, ramps or getting under the vehicle. 2015 Range Rover Autobiography 4.4 SDV8
Post #658106 28th Feb 2023 5:20pm
RRover
Cheers for that - I've made careful note.
The donut?!?
Post #658108 28th Feb 2023 6:06pm
mjdronfield
Plastic ring on top of the engine when you take the acoustic cover off.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #658112 28th Feb 2023 6:31pm
Kot
So does this mean dealers and most of us using the vacuum pump method are not draining this second turbo sump? 2018 SE SDV8 4.4 Byron Blue
Post #658120 28th Feb 2023 7:14pm
garyRR
The turbo of course also cycles through oil so it doesn't necessarily sit there and go old. I think it's around another 100ml (ish) that can be removed, so compared to a 9L fill, the figure is insignificant. 2015 Range Rover Autobiography 4.4 SDV8
Post #658121 28th Feb 2023 7:19pm
RRover
Wasn't the vacuum pump thing so that Dealers could cut their service time periods down by not having to remove the under tray thingies? Not that service prices reflected this... Whistle
Post #658124 28th Feb 2023 7:26pm
RRover
So is the additional drain plug simply there to enable a drain of the turbos on their own so that work on them is less - oily?
Post #658159 1st Mar 2023 10:48am
garyRR
Most likely so for maintenance to the turbo.
The workshop manual doesn't say to remove oil from here as part of regular maintenance, even by the draining method.
As with any turbo engine, the best advice to prolong turbo life is to wait until the engine is up to operating temperature before using boost (in the case of the first turbo on the 4.4 TDV8, that isn't really possible, so best advice instead is no hard acceleration whilst warming), regular oil changes, and allowing the engine to idle and the turbos cool (through circulation of oil) before switching the engine off. A slow drive down your street and reverse onto the driveway or reverse park then let it lower to access mode is usually ample, without needing to sit there for a few minutes. 2015 Range Rover Autobiography 4.4 SDV8
Post #658160 1st Mar 2023 11:06am
JayGee
No need with modern water cooled turbo’s and synthetic oil to do a rundown / cool down / idle before shutdown but be aware that oil temps lag a long way behind coolant temps on cold start - give it at least 20mins more. 2012 TDV8 Vogue (L322)
Post #658163 1st Mar 2023 11:44am
RRover
All great tips.
I know I've never pushed ANY vehicle (last was a Jag XK8 - or DB7 lookalike) in the least bit, even on motorways if using them, at least not until engine temps have been reached, or as far as the half way settled mark on the gauge is showing. But you can kinda feel this to some degree - with the engine not responding as freely (obviously quicker to warm up in hot summer time) until everything has heated up and the oils/lubs are free flowing. I do get that clicky clicky sound near the front fan or rad area especially on cold starts, but it has done that since I've had it - four and a half years now. I've forgotten the name of the part (is it viscous coupling or something?!?) but owners have had the part changed and the sound is back a week later. So I just leave the sound to itself.
I remember years ago some of my neighbours (when I lived in London) even during very cold winters would rev the bejesus out of their cars on cold starts - sometimes for ages... 10-mins etc - and then wonder why and then complain that their vehicles were always packing up or blowing up on them?!? And you try telling them it could be harming the engine, and the daggers are soon heading for you.
Wink
Post #658170 1st Mar 2023 12:04pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
If check maintanence history on mine, I can see always new drain plug bolt. So on mine 4,4TDV8 oil was drained from turbo reservior always with every maintanence (of course never know was it really drained or just add to invoice).
Yes, there is about 50-100g of oil only, but better to drain it also. And bolt need to be changed as well in this case.
Separate turbo drain reservior is made to allow drive in offroad conditions with inclination to the sides. Without it engine oil level may be higher than turbocharger in steep slope, oil drain is impossible in this case and will sink the turbo. Separate oil pump pumping oil out from there always during engine running.
The idea was good, but this oil pump location is too high. Thatwhy this system is not effective. When reservior goes empty and pump suck air, it stop sucking. Therefore they made drain mod. Its just bypass straight in engine block. So finally its useless system.
Post #658217 1st Mar 2023 9:23pm
