Home > Maintenance & Mods (L322) > V8 4.4 Petrol has started stalling?
jm1489
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
In the last few weeks my 2002 V8 petrol/lpg has started stalling? It starts fine, no warning lights etc.. I can drive for several miles, just did a 20 mile trip to get fuel and it stalled coming out of the garage... started up again and ran fine for another 10 miles. I replaced the fuel pump and filter before Christmas due to a no start. It will stall on petrol and lpg, it has done it when turning into a junction and at a roundabout today but also when running straight?
I did wonder if it might be linked to the E10 fuel, not sure how and it happens when on lpg? Hard to find the issue as it is very random and no eml?
Post #620409 18th Jan 2022 2:45pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Does it stall only when turning? If so may be worth checking your pulleys for one that may be sticking and causing excess load on the engine when trying to turn (thinking about PS pump here).
Sorry missed part of your post where you state it also stalls when running straight.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #620417 18th Jan 2022 3:03pm
Gsxr1250dave
Mine was a simple fix, the new spark plugs fitted during the rebuild started to give out. Replaced for standard single core plugs problem solved.
Post #620429 18th Jan 2022 4:32pm
jm1489
What symptoms did you have... plugs, rocker gaskets and PCV next on list. My RR runs smooth, a tiny miss on idle but hardly noticeable and nothing on lpg. I wish the issue would chuck up a warning light! My gut feeling is that its something electrical but it happens so randomly at all operating temps and different miles?
Post #620521 18th Jan 2022 11:43pm
jm1489
Ivan
My steering does feel a little notchy but I have put that down to the icy driving conditions and a slightly worn inner tie rod, new one has been sitting on the kitchen shelf for several months! Older RR aren't great on the slippery stuff, ideal for mud and snow but not ice! Don't know how a pulley issue would shut the fuel off, alternator is fine, starts right up after the brain fart?
Post #620522 18th Jan 2022 11:48pm
jm1489
Think I will clean the throttle body and have a look for air leaks as my next job? Some posts have suggested MAF sensor but it's strange how it only happens occasionally? Just driven car back from business, approx 4 miles and it stalled three times when slowing down to a stop on both petrol and lpg? I thought it would stall again as revs dropped to 500 rpm and then it picked up? No problem with cold start this morning.
Post #620558 19th Jan 2022 10:10am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I had a similar problem. Cleaned the MAF sensor & was fine then on.
Post #620581 19th Jan 2022 1:41pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
+1 for MAF. Replaced mine for a new Bosch. Symptoms were same as OPs.
Post #620583 19th Jan 2022 1:47pm
jm1489
Will give the MAF a clean and report back!
Post #620591 19th Jan 2022 4:41pm
jm1489
Cleaned out throttle body, MAF and checked for vacuum leaks plus a hard ecu reset. I Have been using the car all day on mixed journeys trying to get the car to stall and so far so good! I think the lpg switches in quicker than before, not that it took ages. Fingers crossed that it just needed a good clean? Only other niggle is an airbag light, diagnostics points to passenger seat power issue... happened the same time I kicked the front chin spoiler back on to the bumper, might have upset a crash sensor? Would reset for a few days and come back, hasn't gone out after a hard reset today?
Post #620707 20th Jan 2022 4:42pm
