Home > Technical (L405) > Should my gear paddles work in 'D' ? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1246 |
Yes it should check your owners manual its all described there.
17th Jan 2022 5:57pm |
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 |
There’s an option in the menu to have them only available in S. With car running in P enter the menu via steering wheel button and navigate to the appropriate menus. |
17th Jan 2022 6:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
As above |
17th Jan 2022 11:59pm |
Minghis Member Since: 03 Jan 2022 Location: South West Posts: 8 |
OK, thank you for your replies, I have found the setting in the menu for the paddle change and selected both D & S which now works for me.
18th Jan 2022 7:55am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
I have to say I have not felt tge need to use the paddles on my 5.0.
18th Jan 2022 9:27am |
To recall memory function you should only have to press the number button to which position you want. By pressing the M button you are overwriting the position stored.
18th Jan 2022 9:55am |
Yes, I do that but the issue is not the process or sequence, it's the M button not doing anything. So, if I want to set position 2, 3 or 4 for someone other than me (through a long process I have set 1 for me) they adjust the seat, then press M then a number other than 1.
18th Jan 2022 4:41pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
Even though we sell the flappy paddle kits for the L322, I rarely use them on the L405. They make a huge difference to driving the 5-speed and 6-speed cars. Less so on the 8-speed cars as it is always in the right gear. Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
18th Jan 2022 5:31pm |
