Home > Technical (L405) > Should my gear paddles work in 'D' ?
Minghis
I'm getting used to the FFRR slowly but can I ask, should the flappy paddles work in 'D' as mine don't, it suggests in the handbook they should...
To get them to work I have to be in 'S'.
Also, the memory function on the seats - I have to press and prod quite a lot to get the 'M' to illuminate to set the memory function, is this normal? Starting to worry I've got a car with dodgy electrics already and it's only a month old..
Can anyone confirm if this is a fault or normal? (2021 71 plate Westminster D300)
Thanks in advance!
Post #620324 17th Jan 2022 5:38pm
Kot
Yes it should check your owners manual its all described there.
Steering wheel paddle shifts: Allow manual gear selection while the selector is in either the D or S position. Lightly pull the left-side paddle shift for down-shifts. Lightly pull the right-side paddle shift for up-shifts. The paddle shifts can be effective when rapid acceleration and engine braking are required. A gearshift indicator warning lamp illuminates briefly at the recommended (up-shift) gear change point. With D selected, each manual gear change via the steering wheel paddle shifts is temporary. The manual gear change is held while the driver is accelerating, decelerating, cornering, or continually requesting manual gear changes. See GEARSHIFT (GREEN).
https://www.ownerinfo.landrover.com/docume...c/G1800124
https://www.ownerinfo.landrover.com/docume...c/G2171761 2018 SE SDV8 4.4 Byron Blue
Post #620326 17th Jan 2022 5:57pm
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
There’s an option in the menu to have them only available in S. With car running in P enter the menu via steering wheel button and navigate to the appropriate menus.
Post #620329 17th Jan 2022 6:17pm
As above Thumbs Up
Post #620362 17th Jan 2022 11:59pm
Minghis
OK, thank you for your replies, I have found the setting in the menu for the paddle change and selected both D & S which now works for me.
I'm still confused about the memory button for the seats though, sometimes it works and sometimes not, I can't see anything that says it won't operate at all times if the car is on. The button lights up when pressed, or should do, but mine doesn't always.
Appreciate the replies, thank you!
Post #620369 18th Jan 2022 7:55am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have to say I have not felt tge need to use the paddles on my 5.0.
Whenever I drive the Abarth, it's flappy paddles all the way. Totally different driving style. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #620375 18th Jan 2022 9:27am
deansmith
To recall memory function you should only have to press the number button to which position you want. By pressing the M button you are overwriting the position stored.
Try this: Switch on car. Press M, release M then press 1. This position is now stored as 1. Move seat all the way back, press M, release M then press 3. This position is now stored as 3. So, from this position only press 1, this should move the seat forward to position 1.
Post #620377 18th Jan 2022 9:55am
Minghis
Yes, I do that but the issue is not the process or sequence, it's the M button not doing anything. So, if I want to set position 2, 3 or 4 for someone other than me (through a long process I have set 1 for me) they adjust the seat, then press M then a number other than 1.
When M is pressed it changes colour, then there's a beep when the number is pressed effectively setting that position. It's the pressing of the M to set a new position that doesn't always work.
It's like the M button is faulty, sometimes it works and sometimes not. I wondered if it was a case of 'they all do that' before I get it booked in for a check.
Post #620430 18th Jan 2022 4:41pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Even though we sell the flappy paddle kits for the L322, I rarely use them on the L405. They make a huge difference to driving the 5-speed and 6-speed cars. Less so on the 8-speed cars as it is always in the right gear. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #620441 18th Jan 2022 5:31pm
