![]() | Home > Maintenance & Mods (L322) > TDV8 4.4 oil filter wrong part? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I am always surprised by how much the filter on the right in your photo sticks out of the bowl , but I have used that type many times and it always works fine when torqued down to 27 Nm.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4324 ![]() ![]() ![]() |
Yep. I spotted that. Left is oem. I fitted a Mahle. Lots of us have. No issues Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks. Does the filter housing adjust to the different lengths via the torque setting?
The spring tensioner is in the bottom of the housing.
I’m guessing the flow of oil is up the centre and drains back down the sides? 2012 TDV8 Vogue (L322) |
Ah - will repeat with engine off (which is easier now I have a new battery)Thanks! 2012 TDV8 Vogue (L322) |
